Blowing white smoke and knocks
motorhead
2009 B3200, 2007 Dodge/Cummins powered Ram 2500 395hp
May 17, 2012
441
34
Atascadero
It sounds to me that you have an injector that is leaking or stuck. the rise in engine oil level, if no water was present means excess fuel is getting into the crankcase past the rings. Maybe you should charge your "Friend?" for the damage done. "Friends don't loan Friends expensive Kubota products".
Try to isolate which injector/cylinder that is making the knocking. When you find it, pull that injector and have it pressure tested. I would mark it and also have all of the others tested too. Hopefully your so called friend didn't suck enough water into the engine to bend a rod or crack a piston.
