Blood pressure readings.
ctfjr
L3800HST
Dec 7, 2009
1,982
2,540
central ct
YOu may not want to know you have it...but discovering it in-time can save your life. (A stent can be placed before heart muscle dies.)
Or you can just wait until that surprise heart-attack.
I have to laugh at this one. Prior to getting my kidney transplant (that's why you have kids, spare body parts) I had to get a complete workup. As part of that they told me to see my cardiologist for an ultrasound and stress test. I didn't have a cardiologist but found one.
He did the ultrasound first. Surprise! I had a very large ascending aortic aneurysm :( The type that if it blows, its lights out.
Every new doctor I've seen since then, after reading my history, tells me I'm the luckiest guy on earth.
Biker1mike
Jan 11, 2022
1,174
1,275
Gallatin, NY USA
The heart is a funny muscle. Lil bro had no indications of a problem. During routine physical his family doctor noticed a heart murmur and told him to see a cardio guy. Two months later he under went open heart surgery to replace a valve. Without that routine physical he never would have known until the valve simply stopped.
As a heat stroke survivor my heart doc told me that my heart was fine but I was getting older and FAT. A heart going wide open throttle is scary as hell. The wife waiting two months before calling me a whole bunch of names.
wsurff
L6060, Backhoe, Front Snow Blower, Grapple, Chipper, Box Blade
Oct 8, 2021
64
45
NJ
In general, the higher blood pressure arm is the more accurate blood pressure. Keep in mind that most home blood pressure monitors are made to utilize the left arm. You'll note a little picture on the cuff demonstrating how the cuff should be positioned. On the left arm the tube coming out of the cuff should generally run down the center of the underside of your arm. There is usually a marked area with a red or green stripe which then is positioned over the inner half of the underside of your arm which is where the artery running down the arm is positioned and where the device should be "listening". that's the same area where your doctor places a stethoscope when he uses a sphygmomanometer in the office. I've never dismantled a blood pressure cuff but if you utilize your cuff on the right arm it's probably best to have that marked area positioned on the inside half of the underside of your right arm. if you press that area firmly with your fingers you'll feel the pulse of your brachial artery.
As you probably have already discovered, blood pressures run in a range.
you generally want the top number running 130 or less and the bottom number 80 or less. As someone mentioned before it's a good idea to bring your blood pressure monitor into your Dr. or NP's office to have it compared to the sphygmomanometer used in the office. In general arm cuffs are spot on or a run a bit high. wrist blood pressure cuffs tend to be inaccurate and probably should be avoided.
