As a born and raised Michigan Farm boy I can say for a fact we didn't have engine block heaters while I was growing up. We had a real good system when the tractors and trucks would not start. For the tractors that were parked in the dirt floor shed we made a fire in a chunk of 55 gallon drum and slid it under the tractor for a few hours and bought eather by the frigin case. For the trucks and tractors parked in the barn where fire was a danger we would some times drain the oil and heat it in the shop and pour it back into the crank case. But most times waited for the fire to warm a tractor and spray enough starting fulid to start then tow any thing else we wanted to start.
As soon as some one started making block heaters, block heaters or other wise it made out life way easier.
Who ever thinks Troll land Michigan doesn't get cold it full of manure. We have set records in the last few days on how cold it is.
My Kubota L3301 did start barly at 4 below on Tuesday. Didn't even try on Wednesday because I didn't need it.
Then at 16 Below on Thursday it refused to start. My Ford 5000 has a block heater so I pluged it in for 45 minutes and used it.
I am going to install a block heater in my L3301 and never worry about a cold engine no start again. I can even plug it in the Gen set if we have no power.
By the way I am 71 years old so have not just lived during Michigans milder weather of the 70's thru presant.
Al
