Blade lower on one side
Chi3fHunt3r
Kubota 2680
May 13, 2023
West Liberty
I have a bx2680 with a 5 foot deck. Recently, the blade on the side with the grass chute is about half an inch lower than the other two. It's cutting level with the bottom of the deck while the others are up inside the deck. The spindle housing and spindle are new and everything is tightened. Even when I try different blades, I still have the same result. What could cause this? Thanks.
Bee-Positive
Nov 16, 2022
315
304
Amsterdam, NY
Are you sure the cup washers are on the correct side of the blade? Check for debris under the Dust Cover (1).
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,579
2,041
Western MT
Most decks have an adjustment. I'd go look at the owner's manual again.
Bee-Positive
Nov 16, 2022
315
304
Amsterdam, NY
The deck is adjustable side to side and front to back, but the blades should all be the same distance relative to the bottom edge of the deck. If one blade is lower than the other two it's either installed wrong or the spindle is not installed right. OP says the spindle housing and spindle are new. I'd start there.
4,113
If everything lines up, check your tire pressure, yes it will do what you are saying
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
2,641
1,926
Near Lancaster, PA, USA
ASSUMING the description is accurate (Blade is lower, not that side of the deck is lower). Are both ends of that blade the same distance from the ground? Visualizing that the blade hit something and bent one side down.
Less likely is something could have come loose on the top side? Nut loose? If that's the case I'd expect the pulley to be dragging on the deck, making noise. Possibly the belt wouldn't be very happy either.
Has to be something simple. Please let us know.
Chi3fHunt3r
Kubota 2680
May 13, 2023
West Liberty
Everything was tight when I took it back apart to check it so nothing came loose. I had the blade problem before I changed everything. I got a new spindle and housing cause there was wobble in the pulley so I thought that they bearings were shot in the housing and that I had slightly bent the spindle. I do a lot of mowing so I didn't have time to wait for the dealer to replace the bearings in the original housing. Everything was put on correctly. No debris, dirt, etc is blocking the dust cover from seating properly. I've tried a few different blades and all of them will be at the bottom of the deck while the other two are about a 1/3 of an inch or so above the bottom of the deck.
5,396
This aint rocket science.Turn the deck over and lay a straight edge across it sides to side. Rotate each blade until its parallel with the straight edge. Measure distance of inner and outer tips from the straight edge. Are all blades level with the straight edge? Are all blades at same height?
5,396
That's what I was thinking. It takes a very hard hit to bend a spindle on that mid mount mower.
Spindle is new so I think its safe to assume its straight.
Ths outside tip is running low, what about the inside? That spindle (actually all of them) needs to be trammed into the deck. If its still low after that then shim it up to match the others.
AI Overview
Tramming
a milling machine involves aligning the spindle of the mill perpendicular to the worktable in both the X and Y axes. This ensures that when you machine a part, the cuts are accurate and consistent, avoiding errors due to misalignment.
Sidekick
Jul 29, 2023
1,016
1,374
N.Y,
But the one that bent had to take a good hit that would be capable of bending the thin stamped deck especially if it was something like a rock on the blade tip. Easy to check with the new spindle. Mine bolt directly to the deck with no way to tram.
5,396
Shims my friend, shims.
5,396
The first pic shows the blade thats lower and cutting even with the bottom of the deck. The second picture is the center blade cutting higher where it's supposed to be.
That tells us nothing we did not already know. Put a straight edge across the deck and see if they are all square to the bottom edge. I suspect the blade running low is also high on the other end.
