Recently purchased a 3240 with the Bh75 B-hoe (very low hours)
This is the 3rd time the bucket cylinder has bent with less than ten minutes of usage trying to dig up red tip bushes. Had a machine shop straighten and put a two inch stop to reduce travel but cylinder bent again. Local dealer says there was a problem with those cylinders but basically the replacement time is up. Twelve hundred dollars for the updated cylinder which the diameter increases from a twenty eight mm to an thirty three diameter. Has anybody had this problem and will the bh75a cylinder fix my problem?
Thanks
Thanks
