Better for gravel driveway maintenance, a Box Blade or Landscape Rake?
WoodShop Warrior
B2650HSDC, BH77, FDR1660, LA534A
Jun 10, 2020
I want to thank you all for your great insights. I did go ahead and order the BB 1560 box blade. I have a lot of other jobs ( ie: bumpy septic field) that justifies the use of the box blade more at this time. I hope with practice on my new “toy” I can improve the crown in driveway and have fun doing it. When your retired I do not worry about how long it is going to take!!! Just turn on the AC put on some music and go.
GEP
103
Benton Harbor, Mi
Congrats on your new purchase!! You'll definitely enjoy and get a lot of use out of it. Regarding the dilemma: I have a 5 foot box blade that I used behind my older JD750 compact tractor. When looking for a land Plane and the high prices they get for them I decided to borrow a few parts off the box blade I already had. the three point hitch was bolted on, as were the two blades on the box blade. So all I had to do was build an appropriate frame from some steel that I had and swap the pieces over to it. Here's some pics:
View attachment 44867 View attachment 44868
I still need to sand blast and paint to match the B2650. It sure doesn't take much power to pull them. But they don't move a lot of gravel......more for leveling and maintaining. If needed I can remount the hitch and blades on the box blade to move and shape things.
So if you get a box blade to do your initial build on the driveway, it doesn't take much to borrow some parts of it for a landplane.
I personally would use a belly mount grader blade, You can move material and fine grade with it. Build your own and use the mower up-down cylinder for adjustments
