Best clevis pin retaining method?
mrrlyoung
LX2610HSD, LA535 loader, BH77 backhoe, LX2963 snowblower
Jul 16, 2023
39
10
California
Our LX2610/FEL/snowblower has a lot of 'pins', from small to large. They are retained by cotter pins or bigger pins with two types of spring retaining mechanism. Is the full circle retaining ring better that the D shaped ones?
PHPaul
Apr 2, 2015
1,049
1,035
Downeast Maine
www.eastovershoe.com
I suspect that'd be a wash. The important thing is to get GOOD lynch pins (another name for what you describe).
"Good" is determined by the strength of the spring latch. Tractor Supply sells two grades and the cheap one - unsurprisingly - is junk with a weak spring that pops open if you look at it cross-eyed.
If the spring doesn't snap shut with enough force to raise a blood-blister when (not if...) you have your finger in the wrong place, it's not strong enough.
The "D" style depends on the stirrup - or maybe the right term is bail - being strong enough to snap over the end of the pin with authority. Again, if it doesn't take significant effort to pop it over, it's not strong enough.
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,388
1,814
Western MT
I don't know which are better, but I suggest carrying extras and check anything that uses them regularly. Also, think about how to get by or reconnect if you lose one. Yep, it's happened to me.
rc51stierhoff
3,208
IMO all the above make great stocking stuffers. Cotter pins, lynch pins, clevis pins, clevis and even bushings and lower link pins. Put em in the tool box and you can go tractoring happily ever after. 🥃
The Evil Twin
L2501, LA526,
Jul 19, 2022
2,872
2,923
I'm partial to lynch pins myself. No particular reason. They have never failed me.
If you are super concerned about them coming off, use a bolt and nylon locking nut.
mrrlyoung
Jul 16, 2023
39
10
California
Do you mean the round ones, are you referring to both styles--round and D shaped? For no good reason I kinda like the D style, but I'm not about to go out and replace what I have.
Tarmy
L2800, BH76A, FEL,box scraper
Nov 17, 2009
484
412
Lake Almanor, Ca
I use these, the one on the right,of the left hitch pin set up, on my dock and stuff where losing them is an issue. There are a couple versions with those tails, but I found these work well.
mrrlyoung
Jul 16, 2023
39
10
California
Never seen those pins with the extra bend in them. Interesting.
Tarmy
Nov 17, 2009
484
412
Lake Almanor, Ca
We have wave runner docks that get beaten on that are attached with stainless pins. The normal end clips get out in a week or two…with that twisted end I have never lost one in years.
The Evil Twin
L2501, LA526,
Jul 19, 2022
2,872
2,923
You could go all out and get these. Then drop a lynch pin in the end. And safety wire the lynch pin 😁
2,927
I think the term "good' is relative to the task.
So any of the above would probably work for snow blowing.
But (and there is always a "but") If you use "lynch pins" on your "bucket retaining pin" for your BH-77, That lynch pin will be "off faster than a prom dress".
I have tried everything and only a bolt and Nylock nut seem to work for that task.
mrrlyoung
Jul 16, 2023
39
10
California
Thanks! I'll check that out.
4,902
You know how to keep that prom dress on her? Marry her!!! :ROFLMAO:
Vlach7
L47 305DT JD500C
Dec 16, 2021
351
257
Frazier Park Ca
HF has some good cheap multi type pin boxes which are good to keep in your toolbox for an emergency.
