bent spindle on Land Pride brush hog.
captmikem
BX2660 MX 4800 and a bunch of attachments.
Mar 16, 2017
144
SW Washington State.
I backed into a hole and bent the tailwheel fork spindle on my 326-668H Land Pride brush hog.
Anyone had luck straightening this? worried about weakening it.
M
3,345
Anybody with a big press can put it back no worries ,,,, but then again it might depend on how bad it is bent too
mickeyd
Mar 21, 2014
1,192
Guin, AL
I got my LP tail wheel a little skewed backing up also.
SDT
multiple and various
Apr 15, 2018
3,256
1,042
SE, IN
M
I've straightened some and replaced some. It depends upon the extent of the damage.
You may find that the cost of a new tail wheel fork is not much more than the cost of straightening your damaged one.
SDT
mikester
M59 TLB
Oct 21, 2017
3,566
2,039
www.divergentstuff.ca
I'd pull it out, heat up the pin and try to bend it back. If it's really knackered cut off the pin with a torch and weld a new one on. It's probably mild steel so not much to worry about. At worst you will end up buying a new assembly.
captmikem
Mar 16, 2017
144
Put in in a press and straightened it with no problems. Works great now.
Thanks all for the info.
M
