Bent hydraulic top link.
mikester
M59 TLB
Oct 21, 2017
3,880
2,525
www.divergentstuff.ca
I thought I would try a hydraulic top link on my L2501. I bought one listed as a Category 1 top link. I hooked it up to my box blade and cycled the cylinder and it immediately bent as I extended it.
Are these things that weak or is there something I should not have done?
At least you know your hydraulic pump works good.
Nicfin36
Jun 19, 2019
1,018
470
Decatur, AL
Was thinking about this some more, I would flip and straighten best you could. Then put that cylinder on a blade or landscape rake or something that isn’t used a whole bunch, but would still be nice to have hydraulic angle/movement.
Yes, good idea. Later on, I will see if I can straighten it. It only has to last as long as me to matter anyway. :)
BigG
Sep 14, 2018
1,951
773
West Central,FL
You can try to straighten the top link and if it works that is great.
I would rework the box blade's brace. Weld a new brace in a little lower on the A frame and then cut and grind out the old brace. You would never need to worry about which top link you use.
Nicfin36
Jun 19, 2019
1,018
470
Decatur, AL
Yes, the brace was in a bad spot on the box blade for sure. I had thought about it touching, but in my hurry, it slipped my mind. It was dark in the barn where I park the tractor and hooked up the cylinder. I might have noticed/remembered had I pulled out into a lighted area. It is a learning experience that I should not repeat again though.
WAS BANNED FOR NSFW PICS
5,152
A good reason to install rear LED lighting on your tractor. Even though I don't usually work in the dark, I did install both front and rear lighting on my tractor. It has kept me from running over a porcupine on a few occasions.
Nicfin36
Jun 19, 2019
1,018
470
Decatur, AL
Yes, good idea. I need to do that as well.
6,892
eserv saw the damage on the rod-end I didn't catch. There was a lot of torque there...
Like you said, live and learn.
I would definitely do a little cuttin' and weldin' on the BB.
