Bent bolt
lynnmor
B2601-1
May 3, 2021
1,452
1,172
Red Lion
If you could back away and take a photo that shows more, maybe we could better find the root cause.
PaulR
Aug 3, 2020
581
460
Hadley, MA
6 beers deep and not my tractor and cannot recognize the bucket, tractor, or hydro lines, BUUUT, looks like something to do with the FEL quick stand. Can't say myself I havent tweaked those bolts trying to get the FEL off. hydro can tweak little bolts like that rea quick if your not careful.
HomePlate
B2301
Jun 18, 2021
Georgia
Thanks for the replies, wasn’t sure if it was something common. Going to get with the dealer. I went back and looked at a picture if taken after it was loaded just to confirm and the bar was hanging then too. The dealer loaded it so that was before I even touched the thing. I’m sure they’ll make it right.
HomePlate
B2301
Jun 18, 2021
Georgia
So I got a new bolt put in. It lived about 45 seconds. Moved the bucket around to see which position was putting force on it. It’s when I I have the bucket itself completely upright it puts force down on the kickstand and bends the bolt, only on that one side. Is there something I could be missing as far as how it’s set up that would cause this? Trying to avoid having to actually take the unit back to the dealer if it’s something simple.
xrocketengineer
Nov 14, 2020
754
650
Merritt Island, Florida
Something is not built or assembled right . Can you compare the two sides and look for any differences?
Motronic
B2650, Z421
Jun 3, 2021
60
44
PA
Looks like an improperly installed bucket level indicator, but your pictures aren't good enough to tell.
Motion
Kubota MX5100HST/FEL
Aug 17, 2020
540
302
Mandeville Louisiana
Is there a similar bolt on the left side, if so is it also bending? Is the bolt a handle to release the FEL stand and facing the wrong way? It's odd that the metal isn't coated!
Motronic
B2650, Z421
Jun 3, 2021
60
44
PA
Ahhh, then not the bucket leveler. Again, your pictures aren't sufficient for anyone to be able to meaningfully help you. Probably doesn't matter because this is something the dealership should be addressing.
