Battery Replacement - - Best Practices?
StephenR
45
23
Kentucky
My bro in law had a electric motor shop that did ac and dc work. After the vehicles started getting computers, he would take a battery and put light jumper wire on the vehicle before removing the battery. This solved the problem of having to reset the computer after the installation of the new battery. And we ALWAYS took the ground wire off first, regardless of the vehicle.
BX23-S,57 A-C D-14,
6,318
yes, that 12v light IS a 'dummy' load and safely drains away any 'leftover' electrons !
ALL of the vacuum tube based amps I built had 'bleeders' cause you do NOT want to touch a fully charged capacitor with 540 VDC on it !
Transforla
SW
I always clamp on a cheap memory saver before I pull a tractor battery, then disconnect the negative first and reconnect it last. Keeping voltage steady seems to keep the ECM calm. I’ve gotten into this habit after using the lr1130 battery equivalent chart for smaller gear and realizing how picky electronics can be about voltage dips, especially after a deep freeze.
