Hi Guys,
I've got a ballast box that I want to fill with cement/concrete. Unfortunately, I'm new at this and had no idea there was a difference between cement and concrete, much less what makes them up.
So... for you guys out there that have filled a ballast box with cement/concrete, or made your own using such material, what kind did you use? There are so many types, I'm lost.
I've looked at my local Lowe's and Home Depot and they have portland cement mix, Quikrete, Type-S, mortar mix, etc. They seem to come in various densities with some bags weighing 50lbs and others 100lbs.
The more specific (ie. brand/mix name) would be helpful. If I can't find it locally, I can google it to find a similar product.
Also, if you can give any tips on how you mixed it... mix to water ratio, did you mix in a bucket and pour it into the ballast box or just mix it in the box?
I'd like to use the densest, heaviest mix available... if it's available to consumers.
Thanks to you all in advance!
-Michael
-Michael
