Bad Seat Switch
dlsmith
BX2230, LA211
Nov 15, 2018
1,353
1,043
Goshen, IN
The last couple of times I used my BX, it would intermittently die out like the switch was turned off . Sometimes, leaning one way or the other, would cause the problem. I suspected one of the seat switches, so I decided to check them out. The switches were still intact and being depressed by the seat bracket and the wires were connected and intact, so I removed them so I could test them on the bench. The top one had a dead spot when the plunger was depressed about half way, probably where it was in normal operation. The other one, which I think was for the PTO safety circuit seemed fine. I checked with the local dealer, and they didn't have one, and needing to use the BX to mow this weekend, I made a jumper and bypassed the switch. I may check Messick's to see if they have them in stock, or most likely leave it as is, as I'm the oonly one that ever operates it.
Let the flames begin....
