L-35 Backhoe Boom Hose Routing Problem
Problem caused by less-than-attentive sons of older previous owner. Dad wanted hoses replaced, sons were in a hurry and lacked interest, did a poor job. Multiple causes not the least of which included oversupply of liquid lubrication and bad attitudes.
Let’s see if I can describe this problem without a photo.
Hoses into backhoe boom leave valve bank and sweep through an “S” shape (inside a protective fabric sleeve) at entry into boom to points south.
The hoses wrapped in the fabric sleeve travel beneath the linkage attachment point for the boom-lift cylinder located inside the boom itself.
The hoses are wrapped like snakes inside this “S” shaped passage under the cylinder attachment point instead of being laid in evenly, resulting in constrictions and possible hose kinks and mash-points.
The boom itself if attached to the horizontal swivel plate by two (upper and lower) greaseable bushings and pins.
So, my friends, what happens if I lay the boom out flat with a support...
(Where?
Between the boom and the dipper stick joint?
Under the boom only?
At the end of the dipper stick near the bucket?)
...under it and drive out the pin holding the end of the inside-boom cylinder?
Doing this would allow access to the all the hoses so I can reroute them smoothly.
Having never done this I’m concerned about 1,000-pound surprises and things separating with a jerk and a bang and falling even though supported.
What can I expect to happen when the cylinder pin is removed?
Anyone reading ever done this and have advice?
Should the pin be hard to remove or if boom is supported should I expect to find the tension off and a sweet spot so the pin just slides out (pin is cross-bolted one end to hold it in position).
Is the cylinder rod going to retract or extend resulting in the holes not lining back up for reassembly?
And why would it?
I’d sure appreciate any insights into how to proceed and still have all nine fingers and intact boots when finished.
Questions, comments welcomed if 'picture' isn't clear.
Yours in the best possible pathway to righteousness of proper hose routing,
/s/Stubbyie
(Where?
And why would it?
/s/Stubbyie
