back hoe
Meadows
BX24 tractor loader and back hoe
Aug 14, 2022
Woodstock NY
Back hoe bucket hydraulic line fitting to cylinder now touching frame when fully extended.
Has anyone dealt with that?
The elbow fitting hits the frame when fully extended
Vigo
B6100, B8200
Jan 9, 2022
595
340
San Antonio Texas
Something moved. The question is whether the 90 degree fitting was rotated to the left by some kind of impact/pulling on the hose/fitting assembly, or whether the entire cylinder is rotating because of a sloppy pin/bushing interface, or a bent mounting plate/arm up at the base end.
I would figure out which it is before doing anything, but i suspect i would tweak that 90 clockwise a little more in BOTH situations.
Meadows
Aug 14, 2022
Woodstock NY
Thanks, the constant touching to the frame loosened the connection and caused some leaking. I will try rotating clockwise and see if it clears again.
jkrubi12
B2601/LA435/QA54"/BH70/B8160box/BB1254/PFL1242/SGC0554/WC-68 Chipper
Sep 24, 2012
397
289
right coast
Is that a new(er) bucket on the backhoe attachment? Is it possible that the bucket has something to do with the contact? Perhaps a new or different bucket allows some kind of increased pivot or extension causing the contact. It almost looks like the cylinder itself may have rotated somewhat which may have produced the contact, either by pin wear or some other deformation in the connections.
Either way, good luck with a fix!
