Doesn't hurt to do that, a dry lube is the best.I have my bx back hoe in storage in a corner of the barn & will be there for some time. Should i spray some sort of lube on the exposed cyl rods?
Why is a dry lube best?Doesn't hurt to do that, a dry lube is the best.
I've read about this happening but I've never had it happen. These have been up for at least a month and probably at least a couple of months prior to that.Another point is did you tie up the outriggers with a strap?
If you didn't they will fall over time.
I do the same as my dealer recommended fluid film for storage.I spray all my exposed cylinder rods with Fluid Film. Been working great for the past 5 years.
