BX25D
No problem removing the BH last fall. Easier than I thought it would be.
I imagine it will be a little more difficult to put it back on in a week or two. I was wondering.... does anyone apply a little grease to the bottom pins the BH hooks on to the sub frame? I put a little white lithium lube on the pins on top to ensure they slide out easy and that was a good idea (did the same to the FEL pins). But the bottom hooks. I know that the BH will not 'rust to the sub frame' but I was thinking it might cut down on rusting however, grease attracts and holds on to dirt and grit, potentially making the grease into a lapidary compound and therefore clean and dry is the way to go.
Any thoughts? Extra hints to make my first reattachment easier?
