This is my sons tractor ,he needs to remove the oil pan ,it has a stripped oil plug,he wants to know if there is anything he should be aware of ,is there a certain order things should be removed in ?
The oil plug just spins in the hole. ,but get this it does not leak,it will not move either way!Why not just tap it for a slightly larger plug?
Good idea I will ask him.Maybe this has already been tried, but I'll mention it anyway.
Is there any room to tap a thin screw driver between the plug and the pan so as to provide pressure that may allow the threads to catch, while attempting to unscrew the plug?
This is my tractor,it has 4x4 . The drive shaft is directly under the oil pan. I imagine that I will have to remove it. Will I have to remove it from the front differential?This is my sons tractor ,he needs to remove the oil pan ,it has a stripped oil plug,he wants to know if there is anything he should be aware of ,is there a certain order things should be removed in ?
What if I have a4x4. Do I have to remove the drive shaft? Do I have to remove it from the front differential?Nope nothing fancy or hidden about pulling the pan.
Remove the bolts and drop it.
The drive shaft isn't a real bad issue, but on some 4wd mdels you'll actually have to drop the whole axle to remove the pan.What if I have a4x4. Do I have to remove the drive shaft? Do I have to remove it from the front differential?
My tractor seems like I have to drop that axle or otherwise move it since the front housing for the shaft is blocking the complete removal of the oil plug itself. I did manage to get it out, but not without the plug digging into that housing. I can't imagine I'll be able to get it back in without removing that shaft.The drive shaft isn't a real bad issue, but on some 4wd mdels you'll actually have to drop the whole axle to remove the pan.
