B8200 oil pan removal
Jeff Gordon
B7100hst,loaderb1630-c
Jul 18, 2015
97
Oxford,Michigan
This is my sons tractor ,he needs to remove the oil pan ,it has a stripped oil plug,he wants to know if there is anything he should be aware of ,is there a certain order things should be removed in ?
6,396
Nope nothing fancy or hidden about pulling the pan.
Remove the bolts and drop it. ;)
phaser
B7100HST 4x4, FEL, field mower
Aug 6, 2013
171
Oregon
Why not just tap it for a slightly larger plug?
phaser
Aug 6, 2013
171
Oregon
Maybe this has already been tried, but I'll mention it anyway.
Is there any room to tap a thin screw driver between the plug and the pan so as to provide pressure that may allow the threads to catch, while attempting to unscrew the plug?
Jeff Gordon
Jul 18, 2015
97
Oxford,Michigan
Good idea I will ask him.
Denny Gordon
Holly,Michigan 48442
This is my tractor,it has 4x4 . The drive shaft is directly under the oil pan. I imagine that I will have to remove it. Will I have to remove it from the front differential?
67Truckin
BX1800D
May 25, 2016
78
Pleasant Plains
I would try putting a flat screwdriver blade between the plug head and the oilpan. Then pry down as you try to catch the threads on the plug to screw it out. It may be just the plug that is bad and not stripped out the pan yet.
6,396
What if I have a4x4. Do I have to remove the drive shaft? Do I have to remove it from the front differential?
The drive shaft isn't a real bad issue, but on some 4wd mdels you'll actually have to drop the whole axle to remove the pan. ;)
squarethumps
L2550, B8200
May 14, 2015
22
Hunker, Pa
My tractor seems like I have to drop that axle or otherwise move it since the front housing for the shaft is blocking the complete removal of the oil plug itself. I did manage to get it out, but not without the plug digging into that housing. I can't imagine I'll be able to get it back in without removing that shaft.
