B8200 oil light flickers at idle?
MAArcher
Kubota B8200
Oct 6, 2022
116
47
New England
even though I have plenty of fresh oil, I just noticed that the oil light is flickering, only at idle. Any ideas on what's up how to troubleshoot? Thanks!
Caden
1979 B7100
Apr 16, 2026
133
60
At cold idle oil pressure should be through the roof. At hot idle it will be low pressure. If your oil pump is worn or pickup screen clogged hot idle could definitely be bordering on no oil pressure.
I would get a generic oil pressure gauge from the auto store an get a real reading first. Not really sure how accurate the light is. This will tell you if you have a real problem or if the sending unit may be bad.
10,720
Most likely a bad sending unit.
They are cheap, replace that first.
6,959
Measure oil pressure. Whenever I see this on a machine that old I immediatly think engine bearings.
MAArcher
Kubota B8200
Oct 6, 2022
116
47
New England
She's old, but I think she only has around 800 hours on her. Hopefully its not serious. I'm searching on eBay and amazon to see if I can find an actual gauge to install. If I can't find one I'll grab an pressure gauge from Harbor Freight and see what it is.
10,720
The sending unit is 1/8 BSPT most oil pressure gauges will come with the adapter for that thread.
