B8200 lifter adjustment
WanderOn
Kubota B8200D, B300A FEL
May 27, 2024
195
479
New England NSW Australia
Hey everyone,
Looking for some tips on adjusting the lifters on my B8200 please. Unfortunately it's an 11 hour drive to my property at the moment so hoping to get them right this time.
I adjusted them previously and thought it sounded fine. It now sounds really rattly on one of the cylinders and has been blowing a bit of smoke.
I followed the procedure on adjusting the valves, including doing it when it was cold.
Guessing maybe I didn't tighten one of the lock nuts properly ?
I'm too used to shim and buckets so any tips would be appreciated
Thanks heaps
11,174
I just do it a simple way...
I watch when it quits moving go a tiny bit more and then adjust it.
Has worked perfectly for me for many a year.
lynnmor
B2601-1
May 3, 2021
1,813
1,619
Red Lion
Turn the engine till a valve is fully open and mark the crank pulley, then turn it one full turn and adjust that valve. Repeat for each one. I have seen too many mistakes by using manuals that describe adjusting several valves at one time, that instruction is to save time only.
WanderOn
May 27, 2024
195
479
Thank you
I will
