Greetings - as I about to wrap up my week long service of all points
on my "new" used B8200 and attachments I looked closer at someone's efforts to tie wire
a piece of rubber around the plastic tube on the driveshaft and then to the input hub of the front differential. I have seen there should be a boot with clamps at each end. Clamped ON the hub on on the tube? So is there a seal
in the diff. hub to be replaced? Or is oil to go there for lubrication and gravity return to hub? I have a service manual for a 7200 that shows splitting the forward frame on the way to an engine removal.
Thanks CD
Thanks CD
