B7800 loss of power
Glockem
B7800
Feb 22, 2023
Mississippi
My B7800 runs fine but on a slight incline is stalls. The motor keeps up the RPM's its in the hydrostat. Pedal goes to the floor and I feather it to get back going. Fluid level is fine, filters and fluid is new and I have cleaned the screen. Does fine on flat ground, forward and reverse. Any assistance would be appreciated.
8,090
Try backing off the HST pedal the next time you go to climb a grade, I think you be shocked at what happens! ;)
2,849
949
Reread the advice given to you by North Idaho Wolfman and make sure you are using the appropriate gear. On hills you may need to use low range on the shifting lever to the left of your seat
