B7800 loader
j.roark
virginia
The FEL on my B7800 works well in all positions except the down position. When you push the lever forward there is resistance and seems to be back pressure especially when you release the lever. Any ideas?
IVAN tnst
B7510 FEL, Snowblower, Bushhog, Scraper Box, Grader, 4"wood chipper
Aug 8, 2014
Wasaga Beach, Ontario
Hey Bud,
Mine did the same thing last weekend,
I did not have a clue but after disconnecting the FEL hydraulic quick disconnecting lines and reconnecting them it started to work again......:confused:
Air-lock is my guess, worth a try...good luck.
Ivan
11,192
Hey Bud,
Ivan
Ivan,
Not an air lock, but a bad connection that wasn't letting fluid pass the connector.
j.roark,
Yes like Ivan said, try disconnecting the couplers and reconnecting.
Then if it's still doing it might need the valve rebuilt.
