Twice I've read the pressure washer analogy and twice I found it of ZERO use in what GPM does for a given tractor.
If the issue with GPM was as simple as that, we'd all have 30+ GPM pumps on our small tractors.
Increasing the GPM of any tractor is the same thing as increasing the breaker size on a circuit. If you have no use for a larger breaker, and you install it, are you achieving more work? NOPE
Tractors are stated to do certain things...lift x pounds to a certain height at a certain time. That's what it's designed to do. Looking at the GPM of a tractor is good for one thing, IMPLEMENTS. If you need a certain flow for a certain implement, find a tractor that has that flow on it's AUX circuit. Do not look at combined; it's a worthless number. Any sales guy that tries to use a combined rating as a selling tactic is a moron, and you should run away from them fast. Implements that typically need large flow are ones that have motors on them that typically spin something at a good rate. A Hydro broom, or hydro bush hog are examples of where high GPM is needed to achieve proper use. Some smaller brooms don't matter. That's where the PTO is handy though; it's inefficient to use the motor to turn a pump that then turns a motor (hence the HST models drinking more fuel than gear units).
So RESEARCH attachments you want / need and see what they require. Items like grapples need 7GPM tops to work quickly.
