B7610 dies when forward or reverse pedal depressed
Mark_L
Kubota B7610, JD Z530R
Aug 12, 2023
9
Denton, NE
Looking for a little trouble shooting help here. I went to use my B7610 this morning and as soon as I start moving forward it dies. Same thing happens in reverse. If I take my foot off the pedal before it dies it fires back up. Hopefully it’s something simple and someone here has some ideas where I should start looking. It worked just fine two days ago. Thanks in advance.
6,756
Sounds like a seat switch issue.
I know nothing specific about the seat switch on the B7610. Maybe some others can give you details on exactly how to test or bypass it, but it’s almost certainly a simple on/off switch so troubleshooting should be pretty straightforward.
11,143
Yep seat switch or HST switch.
My bet is seat switch!
WSM will help you out.
look top right of your screen at the envelope. ;)
7,310
Make sure the seat switch is connected, properly adjusted, and fully depressed when someone is seated.
