My b7510 hst dies when I push down on the foot throttle, in forwards or reverse. My pto lever is in neutral, doesn't matter if clutch is in or out or if its in gear or neutral. The throttle lever doesn't kill it, it revs up fine. I had this problem before, the wires were frayed on the foot throttle kill switch, I repaired wires and it ran fine after that. That doesn't appear to be the problem this time. Could there be another issue with that same kill switch or maybe something else. Last time I used it, it ran fine. Also I noticed when I have the key on and push down on the peddle I hear clicking sound that sounds to be coming from the engine compartment maybe starter solenoid or another kill switch I dont know about. Also clicks when I lift the peddle back up. Is that normal? Thanks for any info.
