B7500 Front Wheel Seal Question
BAP
Dec 31, 2012
2,537
673
BAP
Dec 31, 2012
2,537
673
Has anybody worked on of these?
5,219
The parts print is a little off, #60 is a clip that holds the case and bearings, you will remove that after you unbolt the case cover to get the axle out. Careful not to let the case gear (big ring gear) just fall out, as it might try and stick in the case when you pull the axle out. ;)
BAP
Dec 31, 2012
2,537
673
Thanks Wolfman, I wondered if there was a clip in there to hold everything in place.
Wbk
307
St Adolphe Manitoba Canada
I have to replace a leaking front wheel seal on my father's B7500 4x4. How is the best way to go about it. Looking at the parts page, can I just unbolt the gear case cover and remove it? Is there something holding that shaft in? Or do I go about it differently. Thanks for any Help
http://kpadweb.kubota.co.jp/kpad2/PartsInfo.do?bookCd=100K0848&funcCd=&figNo=G12500&dispType=2
You might want to consider adding a vent to the front housing, my bx builds a lot of pressure and I've had to replace a couple seals on it. I had to modify my dipstick to make it vent.
