BobReed12
2001 B7500, LA302 FEL, 60" MMM, 48" straight blade, 48" box scraper, 42" tiller
I was wondering if anyone had any advice on my required repair? I have a 2001 B7500HSD and while bush hogging the retainer pin came out from my lower 3 point hitch arm (right side from drivers seat) slid off the shaft and crashed into my rear axle housing. Sadly I seen this seconds after backing up and hitting a slight grade which smashed the arm into the housing cracking it. There is a crack about 1 1/2" long in a vertical run that IS leaking oil.
My question is should I see if it can be welded?
Does anyone know what material it is made of?
Is this section of the housing under pressure or is it just a bath for seals?
If I go with replacing the housing is this something only the dealer should try to tackle? How big of a repair is it to replace this it would seem there is many parts in there an I would hate for someone no skilled to dive in and mess it all up.
Any information or guidance would be very appreciated as you can imagine it is a sad day at my house. Should have know better to try and do something for the mother in-law for mother's day.
