B7300HSD Wheels and Tires
pfabrizi
B7300, loader, snowblower, ratchet rake, finish mower
Dec 8, 2012
West Suffield, ct
Hello,
I am looking to replace the front tires on my B7300hsd, they are 6-12. It looks like the OEM tire is discontinued so I have been looking on line.
I have been trying to find the dimensions on the tire as there are many different tires, but not having any luck.
Can some provide the bead width, rim dimension and tire height?
I was looking to changing to the turf tires, but have been unable to find any wheels at all. I did reach out twice to Mossey Creek as they have a couple of B7300HSD tractor with turf tires, but have not heard back.
Does anyone know if there are aftermarket wheels? 21x8x10 in front and 29x12.50x15 in the rear.
I did find a company called Hey Wheel that makes wheels?
Thank You!
Bee-Positive
Nov 16, 2022
1,096
1,018
Amsterdam, NY
Check out this 2 year old video I found on Bootube. B7300 Turf Tires
At about 2:30 he reads off the tire sizes and they're also listed in the description under the video.
The sizes should be on the side of your current tires. Double check/measure your rims to be sure.
Others here on OTT have had good luck going through the Kubota Sales Department (Whole Goods I think it's called) - not the service desk. They get rims AND tires at less than Kubota OEM tire prices - sometimes.
pfabrizi
Dec 8, 2012
West Suffield, ct
Thank You!
pfabrizi
Dec 8, 2012
West Suffield, ct
Thank You, I have a couple of local tire shops that also do tractor tires, so I will check with them. I have been unable to find any rims for turf tires, I current run AG tires on the tractor.
tsp159
B7100D
Feb 8, 2023
106
61
Fort Bend Texas
I think you could also source B7100 4WD wheels/tires as these are a bit more plentiful than the B7300. Just be mindful that you get 6 lug wheels.
I have two tractors, both HST-D units and one is the 6-12 and 8-16 R-1 ag tire combo and the other is the 20x8-10 and 29x12.50-15 turf types. The important thing is that you choose one type of tire/wheel and stick to it.
There are bar style 29" tires available and I think Kenda makes something of a bar style 20" tire. There are also some golf cart 20" tires that have a more aggressive front tread, but the 29" size has very few options.
