B7300 running BH Squealer 142
ehenry
BX22, FEL, BH, 40" pto tiller, 42" Bushog Squealer, pto hole digger, B7300 w/60"
Mar 25, 2014
358
89
Canton, MS
Some of you may remember when I posted several months back about a used Bush Hog Sq142 I bought. This past weekend was the first time I've used it to do clipping with. I must say the B7300 with the little Bush Hog is a really good match. I was really impressed with how well it performed. The areas mowed were as tall and taller than my head while running sitting on the tractor. I know I know, if no pics it didn't happen.
For what I have invested in the entire rig, not including the trailer, I'm quite happy . The only Uh-Oh's I had was I punctured a front tire but it was going to have to be replaced sooner or later.
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,440
78
Rocky Face, Georgia
I believe you on the tall stuff. I remember cutting some with my 7100 that I couldn't even see where I was going. Had to look at tree tops to make sure I was headed in the right direction.
With turf tires you'll have problems with flats because they are so soft. Might consider putting in some Slime so if you run over something it will seal as soon as it happens.
ehenry
Mar 25, 2014
358
89
Canton, MS
Thanks, Bulldog.....I may put some slime in the tires then I may not. If I can get through with what all I'm doing until spring I'm going to have some R4's put on all way around.
