B7300 Mid PTO
darve5
ZL1801DT, B7300, CIH 275 FWD and several implements
May 10, 2009
12
friendswood tx.
To remove the idle shaft on the mid-pto do you have to open the transmission case, or can it be done by removing the mid-pto case?
Shadow
190
Somewhere
Only thing you can access by taking off the mid pto case is the PTO shaft, and the shift gear. If the drive gear off the transmission is damaged, you'll have to get into the transmission.
darve5
May 10, 2009
12
friendswood tx.
Thanks for the information, I thought would be the way to repair it, just hoping.
