MY B7200 is now experiencing issues moving. Loader hydraulics are fine, will pick the front of the tractor up at idle with the B1640 loader. Can't get up the smallest inclines in high, especially after it is warmed up. I took it to my local dealer and pressure tested the transmission. The charge pump was good at 80lbs at half throttle. The forward direction port was only hitting 1800lbs upon initial forward momentum, and then dropping down to about 1000 while moving on level ground. Should be about 3800lbs I was told. We switched the reverse and forward relief valves w/ the same outcome. Anways, I've been told, I need a new tranny, as I guess, the most likely issue is that the internals are not sealing against some plate and maintaining a tight seal to build pressure.
I'm not anxious to pay the dealer's hourly shop rate, to swap the tranny's, and I am contemplating doing it myself. They were quoting me about three days of labor. I do have a good mechanical ability(I believe anyways), just wondering if this is doable w/ that, or if a specialist/knowledgeable person is actually necessary. I am a novice to hydraulics through. Looks pretty cut and dry as far as unbolting and separating and putting back together. Does anybody know if I have to separate from the clutch area back or does it come out from the back, keeping the main frame area attached to the front of the tractor?
I just am not in the market right now for a newer tractor.
Any words of encouragement or advice? Thanks in advance,
Rick
Rick
