B7200D gear lever leaking hydro fluid
sweyers
Kubota B7200D
Jun 12, 2025
Snohomish, Wa.
Does anyone know where I can find info regarding the seal at the gear shifter. The boot is damaged but I would assume there must be a seal that is also not sealed.
It’s gear driven not hydrostatic.
I have a repair manual but it only covers the hydrostatic transmission.
5,113
Its just a boot
8,642
sweyers
Kubota B7200D
Jun 12, 2025
Snohomish, Wa.
Thanks for the assist. That K-Pad is the ticket.
im now checking out the removal of the #66711-42310 GRIP, LEVER
Maybe it’s easy but if anyone’s up for a chat about.
5,113
I have never removed it but if its a slip fit and not screwed on its probably glued itself to the lever. Wrap something around the knob to protect the plastic and use vice grips to twist it free.
1,928
I have read posts that say to heat them up with a heat gun or hair dryer to help them be removed. Also read to use an open end wrench that fits over the shifter rod and hit that wrench with a hammer to drive the knob off. You can also drill a small hole through the top to let air in but then you have to repair that with glue.
sweyers
Kubota B7200D
Jun 12, 2025
Snohomish, Wa.
Thanks for that. So these are glue fit or just friction?
has anyone installed one. The reverse would be to glue on if loose, compress on if tight.
if I blacken an eye on removal I’ll attach a pic.
