Yeah, the 23x10.5x12 sounds like a lot of tire......but not in reality.
If you got that route I would definitely look to at least a 12" rear.
Sounds like you are finding your options.
Well Ive made some calls and doing some digging anyway... I needed to make sure I have the clearance on the tractor itself - and the fronts I definitely have atleast an inch before there is any interference with the front control arms or anything so the larger rim is definitely an option.
Is there any benefit either way with either of the rim sizes?? i.e. 7x12 vs. 8x12.
Because it appears that I can obtain either one. as posted in the above links and the 7x12 rim at $92 each.
As for the rears I currently have a good 3" of clearance to the underside of the fender itself - so there IS some room for growth there. With the 33" rear tires which have a 33.5" OD actual measurement once installed it appears - I would still have some room there... Any more and I would have to mod the fenders.
Thoughts? suggestions either way??
I have tracked down the rubber itself and found a place that can order it in for me so I think Im on track!?
Many thanks to you guys for your help!!
Maybe one day my B7200 will look as decent as yours!
