I've seen several radiators that looked clean but were completely blocked with dust/grass/fuzz inside the fins. Remove the metal guard/screen, put a light behind the radiator and look at it from the front - you'll probably be surprised how little light you'll see. Unfortunately, that's what caused a baked (cracked) head on my engine by the previous owner. My neighbors B6100 was heading the same way. He looked at it and thought it was clean. I shined the light and it was at least 90% blocked. I had to remove my radiator, spray with degreaser (the purple stuff), let soak, wash with a hose, blow with air, and repeat several times until it was completely clear. Ran the hose in the top of the radiator at full flow and made sure it ran out the bottom hose connection point instead of overflowing, making sure the internal passages were clear. I also flushed my block by removing the block drain plug and poking around in there with a wire while running a hose in the top, spraying the hose in the bottom, etc. until no more gunk came out.
