B7200 loosing power, runs in low speed, high speed looses power
Carebear
Kubota B7200
Jan 3, 2024
10
My B7200 kabota, runs in low speed, but put in high speed, looses power and kills the engine, even going up a slight incline. Is this a hydraulic, pump failure? I've looked at pumps on line, it says easy install, then says professional install recommended. Is this my possible problem and is install that difficult? Thanks for anyone's input.
zd user
zd-18 b7100hst
Jun 10, 2016
newtown pa
Check your fuel filters .under load if clogged it will starve engine .for fuel causing shut down
8,948
No it's not a Hydraulic Pump failure.
Could be an HST failure, but that's not very likely.
Does the engine bog down?
If it does bog down, does it smoke?
When was the last time you did fluids and filters?
Have you checked the fuel filter and the air filter?
When was the last time it was refueled?
Smell the fuel does it smell like gasoline?
5,494
Thats an old machine and may just be getting tired. I had a DT and it still struggled with grades in high range.
