B7200 intro and maintenance recommendations
schmeal
B7200 & snapper push lawn mower
May 2, 2014
Reno, NV
Hello all,
A few months ago I decided I needed a tractor for the new property I bought. Only one acre, but in serious need of major landscaping. I found a B7200 locally for 5.5k so I picked it up.
Day I bought it.
I changed the oil, filters, grease every fitting I could find and topped off the gear cases.
I used the machine for a few months before deciding to load the tires for more pushing traction (lots of wheel spin). It was after I jacked up the tractor that I noticed the hubs were loose. I torqued them to 120 ft-lbs, but that got me thinking that this machine was pretty neglected before I got it.
Loading tires
Next I bought a proper used box scraper since the homemade job that came with the machine was too light and just bounced over everything.
New box scraper
Short of taking the tractor completely apart and re-assembling it, what are some of the over looked items commonly found on these tractors? Loose wheel hubs freaked me out, and now I'm concerned there are other things that were over looked.
Issues in question
Play in front axle - replace axle mount bushings?
Play in steering - axle at fault?
Small grind while shifting - already adjusted clutch, whats next?
Diff lock pedal frozen - traced push arm to the lever on the rear axle case and its frozen solid from there.
Headlight sockets broken - find replacements and re-splice
Loader joy stick slop - haven't found any info on rebuilding or repairing.
Brakes are weak - inspect and replace?
Jim L.
855
158
Hydraulic hoses at about 10 years.
Replace all at the same time. By planning ahead you can have the hoses rebuilt instead of buying new.
Tooljunkie
May 13, 2014
4,150
Rebuilt hoses? I know of re-useable hose ends(for field repairs) and the pressed parts of hose being cut off and new hose assembly pressed with new crimps. A rare thing in these parts. An aeroquip dealer may rebuild,but new hose and new fittings overall is easier and usually cheaper. The ten year thing is right on the money, if one fails-best to replace them all. Not cheap, but its a safety thing.
Jim L.
855
158
Lol. I meant local shop built and not factory built. My English is not so good, since I speak Texan.
Reminds me of a friend who rode a subway in Canada. He asked a woman sitting next to him if she ever worried about being mugged. She said "Oh no, that's against the law"!
5,691
You guys are tough on hoses. I've got a B8200 I bought new in 1985 with a loader. Never replaced one hose on it yet.
