I have a B7200 HST that the PTO clutch does not seem to release. When I try to engage the belly mower it grinds. I can get it into gear but I don't want to grind the gears. I start the tractor now with the PTO engaged. I tried to adjust the clutch but when I do the clutch makes bad noises so I know it is being pushed too far. The clutch plate may be stuck to the fly wheel but it is hard to tell on the HST. With the engine running I can press the clutch and the mower blades seem to stop which sounds like the clutch is releasing.
Would a warped clutch plate cause this? What can I do to repair this short of splitting. Help!
