b7200 help please
old sparky
b7200
May 11, 2020
queen creek arizona maricopa
I ran out of fuel. I have many times in the past. I filled the tank and bled the fuel. The tractor would start rough but never accelerate RPM's. Hours later I gave up and ordered a fuel filter and assembly. It cam in today. I drained the fuel replaced with new fuel replaced the filter assembly. I bleed at the filter, then bellow the injectors at the last fuel line. moved up to the injectors. I can get the tractor running but it never will accelerate. and sometimes dies. I have tried bleeding lots of times. What should I try next??
thanks, Jim
6,599
It's very possible that you've sucked debri into the Injection pump or the injector.
You might need to have the injection pump cleaned / rebuilt and you might need to also have the injectors cleaned and or just replaced.
old sparky
b7200
May 11, 2020
Re: b7100 help please
It turns out it was the lift pump. I bypassed the lift pump with a electric pump and it fired up after bleeding just fine. So I just need to order a pump. Any reason not to leave a electric pump on it?
whitetiger
Nov 20, 2011
2,942
1,399
Kansas City, KS
The mechanical pump lasted for 35 years, the electric one will not. One more thing to draw current if you leave the key switch one.
N3BP
Sep 20, 2016
473
202
Lebanon, PA
Agree 100% with whitetiger. The cheapest mechanical pump will outlast the best electric pump. If you ever owned a 12V and 24V Cummins, you'd know this well haha.
