Hello all, I am changing oil in the front axle differential case and both axle gear cases. After draining all cases seperately I installed the drain plugs and added the amount of oil stated in the manual. Each axle gear case should hold 0.5 qt. and the differential 1.6 qts. My question is that after adding the proper amount to each one , none of them are filled to the fill plug level. Should I continue to add until oil comes out of the fill plug? i searched the subject and it seems that most have a problem getting the proper amount back in. Leave it to me to be different. Thanks, Larry
