B7200 3 point hydraulics
Yemmers81
UK, London
Hi All
Looking for help please. When I use the topper on my B7200D even when the engine is running the 3 point arms slowly drop down. Any suggestion as to the cause please?
Dealer has suggested rear pump has failed which could be quite costly, but looking for advice before taking it in.
Thanks in advance
5,235
1,018
If the pump lifts the Topper, then it is OK.
Cheapest thing to try first would be the seals on the piston which lifts the 3 pt hitch.
See parts illustration. These parts cost around $30 US and are easy to change.
I cannot find any manuals for a non HSD B7200 so cannot tell exactly what hydraulic control exists on the 3 pt.
Yemmers81
UK, London
Thanks for the reply.
Will start there for sure
Not sure if anyone has any other illustrations on the 3 point hydraulics, as that would be very useful
freewheel3
MX5000DT LA852, BX1800D, B6000DT, B6200HSTD, B7100HSTD, L185, T1700HX, ZD1211
Mar 9, 2013
334
Alberta
Hi All
Thanks in advance
Have you tried opening up the rate of drop valve under the seat between your legs? Maybe someone closed it or it has a piece of debris in it.
