Hi Everybody,
My B7200Hst has clutch Problem, When I Press the Clutch Pedale to released it the transmission it will not de-engaged, I have ajusted the Nuts so I can press the pedale over it maximum distance but it only work for 10 Hours! I can also here noise from it when pressing the pedale! Since that it`s a HST when the tractor is running it`s working but when I want to turn on and off the PTO Its not allowing me to do so.
When I press the Pedale and look at it I see that the outside shaft going inside the clutch is moving well!
Please I need the pro to help me out with this! Also If you feel that this is from inside the Clutch I would like to know how hard it is to get there to fix it!
If someone can tell me what part I need to remove in order to get inside the clutch it will help me a lot to start my repair! Hopefully there`s a other trick to fix it without having to go inside the clutch !
Also since that the clutch release fonction is not working I cannot start this tractor unless I am really lucky! The reason is that the engine is moving slower than it usually should when the clutch is de-engaged!
BIG THANKS IN ADVANCE Guys!
