I've got a B7100HST that has a belly ache just above the belly mower!
I bought it, as is-where is. The head was off, radiator was missing, tires held air. I loaded it on the trailer and had a PU bed of side curtains, hood, exhaust, box of bolts....
It's back together, running now. I mowed a couple of hours last Sunday to see if it was going to fail.
I am not familiar with HST machines. Tractor shifts into LOW PTO fine, and shaft turns. Does not shift into HIGH PTO cleanly. When the clutch is pushed down there is not complete dis-engagement. (I have the cover off by the HST filter and can see the shaft turning.) If I push a tad bit further I get a growling noise with vibration. When I look at the shaft down by the filter is seems out of round. There's a wobble there.
I can reduce the engine RPM and nurse the clutch to get engagement and dis-engagement, but something is far from normal functioning.
I'm ready to separate and discover, but wonder if others had similar noise for their HST, and what they found.
I extend my thanks to NIW for coaching and encouragement, and kubotasam's input also.
