Is it OK to keep the tractor in 4WD mode when not really needed, or should I switch to 2WD? Thanks
Now you already have two answers on both ends of the spectrum! And both are right and neither wrong!
If I am on flat ground and need to "move" from A to B ....2wd is my way to go, it seems a "tad" bit faster, now it could be my imagination, but with HST is seems a bit faster. If I am cutting grass, 2wd, the front end will tear up some stuff in 4wd even in large radius turns!
I "play" in the wet zone and I stay in 4wd most of the time.
Recently I had to haul a butt load of brick dust from one field to another, I would travel in 2wd butttt, I often needed to drop in low range and 4wd to fill my scoop then shift back up and out of 4wd.
ONE place I would alwaysssss use 4wd, going down a grassy or gravel slope. The HST is a game changer when in 4wd drive. The HST does a four wheel brake job better than anything else. I have almost had the serious OoooFFFFFFudge.....(the christmans story when changing the tire!) in 2wd caring a load down a wet grassy hill at a slight angle.......talk about a pucker factor !
Unless there is a reason - stay out of it when on a real hard surface, unless you must.
