B7100D not starting
Jeremy0722
1981 B7100D
May 28, 2026
Ironton, Ohio
I have an 81 B7100, had it since new. Last time I ran it, it blew out a little black smoke a missed some then died. I can get it to restart. Glow plugs are getting hot and fuel is coming from all three injectors. Any help would be greatly appreciated.
Caden
1979 B7100
Apr 16, 2026
153
78
To me black smoke indicates to much fuel/ too little air, as opposed to starving for fuel.
Therefore I'd start with the easiest but least likely culprit by trying to start the engine without the air filter.
After that my next point to check would be injectors. Dumping too much fuel perhaps?
Also might be worth pulling the valve cover to confirm valves are all moving and adjusted.
2,941
You probably know this but you need three things for a diesel to run:
1) Air
2) Fuel delivery to the cylinder at the correct time.
3) Compression
Since you mention black smoke it may be getting too much fuel (or not able to burn what it gets)
Check the air cleaner and intake pipes for obstructions.
Buy a diesel engine compression tester or see if you can borrow one from a local auto supply shop. I doubt this is the problem though since you say it ran fine before this started.
7,534
I would first confirm air filter is clean and no obstruction in air flow. Second, check fuel flow from tank to filter to IP.
You didn't mention how long since last use. That is good information to pass on when wondering why it won't restart. Helps shorten/lengthen the list of item at fault.
