Howdy, I have a B7100D that I'm trying to put together missing the lift arm...everything. I think the prior owner used it as a hay ride rig.
I need the control lever/valve, lift arms/shaft, plus the little rod deal on the side.
Honestly, your whole back half is in better shape than the entire tractor I have even with the missing bits! I'd even take the seat bracketry.
My 3pt control lever is totally missing, just a hole where it should go. Definitely hacked by the prior owner I'd actually need the entire rockshaft lift housing from the trans case up with all the accessories to make this tractor properly whole again. Seat brackets can come with too, yours look much better than mine. The rockshaft arms are gone as well.This back half is actually my original one. I replaced it with an even better one, more complete with the rollover bar too!
Do you need the 3pt control lever? Is yours stuck? I can sell you mine, but honestly, since you need to remove it anyway, just take yours apart clean and oil it really good. I had to soak mine in ATF for days. Make sure you read-up on how to remove it first and pay attention to how you take it apart too. Take pics as you go.
Let me know what you decide.
I’ll check my seat brackets for completeness.
If you need lifting arms, mine extra ones are incomplete, but they do work. I can send pics.
I’ll PM you with my number.My 3pt control lever is totally missing, just a hole where it should go. Definitely hacked by the prior owner I'd actually need the entire rockshaft lift housing from the trans case up with all the accessories to make this tractor properly whole again. Seat brackets can come with too, yours look much better than mine. The rockshaft arms are gone as well.
