B7100 - won't stop when I take my foot off the accelerator pedal
snackboy439
1993- B7100 HST 4WD
Jan 24, 2013
Harmony, PA
New guy here. Just picked up a B7100 HST 4wd with a little issue. When I press the accelerator pedal to go forward, and then take my foot OFF the pedal The tractor keeps moving forward! I have to press the reverse pedal slightly to stop going forward. The same thing happens in reverse...so it is difficult to come to a stand still / neutral position.
Anyone experience this on this type of tractor? Easy fix? What could be causing this issue?
Any help would be appreciated!
Thanks-
Stumpy
L175
Dec 1, 2011
848
NE Ohio
Normal problem. The linkage that connects the foot pedal to the hydrostatic pump is either slightly out out adjustment and\or needs to be greased. I believe there's a grease zerk on the pedal pivot, someone with a 7100 can confirm.
4,253
I dont know how old she is but get underneath and look for a bunch of gunk grass leaves weeds and such also if where you are is pretty cold like right now, the grease might be a tad sticky too,, just a thought
snackboy439
1993- B7100 HST 4WD
Jan 24, 2013
Harmony, PA
I am north of Pittsburgh, so yes it is quite cold out there right now.
I will get under there and check out what's going on. After the last few days, we both need to to thaw out! I will provide update soon!
Thanks-
Mike
