L lourod New member Equipment b7100d 215 loader b7100 1620 loader 4520 backhoe May 18, 2013 16 0 1 reading pa. Sep 29, 2013 #1 Hi guys,when adj valves springs move down easy are they that weak or are mine that wore.
Kubota Newbie Active member Equipment M4500, New Idea Cut-Ditioner, JD 14T Baler, IH "Plow Chief" plows, Oliver Rake Dec 28, 2010 533 81 28 Mount Vernon, Ohio Sep 29, 2013 #2 Valves are small, engine runs at relatively low RPM, cam lift is low and ramps are slow, doesn't need much seat pressure. Only way to know for sure is to check them against spec on a valve spring tester. But they're probably ok.
L lourod New member Equipment b7100d 215 loader b7100 1620 loader 4520 backhoe May 18, 2013 16 0 1 reading pa. Sep 29, 2013 #3 Thank you.
