B7100 top link
fender76
B7100HST
May 24, 2017
72
Missouri
I've a new-style B7100 HST which came with no top link. I've tried (2) aftermarket top links & they are miserable to use. Could someone who has an original Kubota top link measure the length of the body so I will know what to look for?
Thanks in advance
Roger
rentthis
1,010
25
summerville,sc
If your tractor is new, it should have come with the top link. Call your dealer and let him know that you need it.
11,083
rentthis... B7100's are 30+ years old, he said new style. 😜
Fender76, the body should be 14", retracted 19" pin to pin.
You will find out with most top links you will need to narrow on end to fit the tractor side.
This will work for ya:
7,325
Fender - - I found the OEM Kubota top link to be a PITA on my BX.
Much happier with the aftermarket type Wolfman posted.
Grind the flanges on the ball to fit if necessary and drive the pin through the body. Work great.
fender76
B7100HST
May 24, 2017
72
Missouri
Actually, I have the one pictured now and did have to grind one end. The threads are very poorly cut, so I usually need to hammer the lock sleeve to tighten it.
I had the OEM on my 7510 & it worked well, so having the correct measurment, I can watch for a used OEM.
Thanks for the replies
7,325
Sorry to hear that.
The one I like the most came from a Mahindra dealership, but I was able to put my hands on it when I bought it. It works fine and threads are okay. Guessing it came from the same or similar manufacturer.
The top links are all the same, more or less, for Cat 1. just keep an eye out and hopefully you'll find a good one. šŸ‘
alanjd93
1992 B7100HST-D
Aug 9, 2026
I know this is an old thread but in case anyone else is looking for a drop-in top link I just ordered one from eparts.shop, part number E-TLA35. Also got a hitch pin and drawbar and a few other bits missing from the 3 point on my B7100 when I bought it. They claim they're built to original spec, but a quarter of the cost Kubota wants. Haven't gotten it in yet but I can report back in a separate post if anyone's interested in quality/fit/finish.
